Enjoy an unparalleled ride with new Skyjacker Softride Suspension Lift Kit
Old Dec 1, 2021 | 09:37 AM
carid's Avatar
carid
Former Vendor
Default Enjoy an unparalleled ride with new Skyjacker Softride Suspension Lift Kit
Skyjacker has been providing premium quality aftermarket suspension lift kits, leveling kits, and shocks for a wide variety of vehicles for nearly 40 years. Skyjacker knows what's important to you and your truck, which is why they've released the new Softride Coil Spring Front and Rear Suspension Lift Kit with 4" Lift Height for Ram trucks. Once you install this kit, you will receive a 4-inch lift on your truck, and you will gain stability and performance too.
Skyjacker uses its new Softride coil springs in this kit to provide an unmatched factory-type ride feel. It is designed to give you all of the rugged off-road capabilities you need while providing the smooth street riding characteristics that you demand.
Prepare your Ram for any adventures with the new Skyjacker Softride Lift Kit!
Skyjacker® - 4" Softride™ Coil Spring Front and Rear Suspension Lift Kit
https://www.carid.com/skyjacker/4-so...r19451k-m.html
Specifications:
  • With Front Coil Springs
  • With Rear Coil Springs
  • With Front and Rear M95 Monotube Shocks
  • Max Tire Size: 37"x12.5"
  • Wheels and tires recommended parameters: 37"x12.5" with 5.625" Backspacing - trimming may be required
Includes:
  • Front Coil Springs
  • Front Track Bar Bracket
  • Front Polyurethane Bump Stops
  • Front Sway Bar Brackets
  • Radius Arm Brackets
  • Rear Coil Springs
  • Rear Bump Stop Brackets
  • Rear Sway Bar End Links
  • Front and Rear M95 Monotube Shocks
