Up to $250 Rebate on Select Ram 4" and 6" Lift Kits by SuperLift
Old Oct 24, 2023 | 09:33 AM
carid's Avatar
carid
Former Vendor
Default Up to $250 Rebate on Select Ram 4" and 6" Lift Kits by SuperLift
Lift your truck to new heights for less with Superlift's limited time $250 rebate! Now through October 31st, 2023, you can save big when you spend $1,250 or more on Superlift lift kits and accessories. This rebate is the perfect opportunity to finally get that aggressive lift you've always wanted.
Going taller allows you to run larger, off-road tires and achieve an intimidating, lifted truck stance. Superlift engineers the highest quality lift kits right here in the USA. Built to last and backed by a satisfaction guarantee, their lifts provide the maximum clearance to conquer rocky trails while maintaining clean street drivability. But act fast, this $250 rebate offer won't last long! Level up your truck and save with Superlift.
Superlift® - 4"" x 2.5"" Master Front and Rear Suspension Lift Kit
With Superide Shocks
Install Time: 8 Hours
Install Difficulty Level: 3 of 5
Max Tire Size: 35""x12.5""
https://www.carid.com/superlift/4-x-...-mpn-k965.html
Superlift® - 4"" x 2.5"" Master Front and Rear Suspension Lift Kit with Fox Shocks
With Front and Rear FOX 2.0 Series Shocks
https://www.carid.com/superlift/4-x-...mpn-k965f.html
Installatio instructions are available here:
https://images.carid.com/superlift/i...structions.pdf
