Get Better Stopping Power with R1 Concepts Brake Kit for Ram Trucks
Old Feb 27, 2025 | 08:02 PM
carid's Avatar
carid
Former Vendor
Default Get Better Stopping Power with R1 Concepts Brake Kit for Ram Trucks
Enhance your Ram truck's braking performance with the R1 Concepts eLINE Series Drilled and Slotted Front Brake Kit with Ceramic Pads, now available at CARiD. This premium brake kit is engineered to provide superior stopping power, durability, and a sleek appearance, ensuring your vehicle performs at its best under various driving conditions.
The kit features cross-drilled and diamond-slotted rotors, designed to effectively dissipate heat and reduce rotor temperature. This design minimizes the risk of warping and extends the lifespan of your braking system. Additionally, the rotors come with a special zinc plating that offers protection against corrosion, maintaining their appearance and functionality over time. Paired with high-quality ceramic brake pads, this kit ensures quieter and smoother braking performance, with less dust and longer-lasting pad life.
Designed to meet or exceed OEM specifications, the R1 Concepts eLINE Series brake kit guarantees a precise fit for your Ram truck. The vehicle-specific design ensures easy installation without the need for modifications. Whether you're navigating daily commutes or demanding terrains, this brake kit provides reliable and consistent performance, enhancing both safety and driving experience. Upgrade your Ram's braking system today with this top-tier kit from R1 Concepts, available at CARiD.
R1 Concepts® WHWH1-40090 - eLINE Series Drilled and Slotted Front Brake Kit with Ceramic Pads
https://www.carid.com/r1-concepts/el...wh1-40090.html
Fits: 2006, 2009-2024 Dodge Ram
2011-2025 Ram 1500
Features:
  • Vehicle specific design which meets or exceeds OEM specifications for exact fitment and equal or improved performance
  • Manufactured with high quality materials which guarantees appropriate weight and strength
  • Quality tested to ensure long-lasting performance
  • Exclusive Cross-Drilled and Diamond-Slotted design
  • Special zinc plating designed to protect from corrosion
  • Allows heat to escape, reducing rotor temperature
  • G3000 Gray Iron
  • Rotor wear indicator
You can browse the full catalog of R1 Concepts brake parts on our website:
Old Feb 27, 2025 | 08:08 PM
carid's Avatar
carid
Former Vendor
R1 Concepts is a leader in high-performance braking, offering top-quality rotors, pads, and brake kits designed for durability and safety. With advanced engineering and rigorous testing, their products deliver exceptional stopping power for all driving conditions. Check out the full R1 Concepts lineup at CARiD and find the perfect brake solution for your vehicle!
Learn more:
https://www.carid.com/r1-concepts/info/about.html
