How to install a dashcam? Let Vantrue show you otherwise!
Old Nov 17, 2025 | 03:47 AM
Vantrue's Avatar
Vantrue
PREMIUM SPONSOR
Lightbulb How to install a dashcam? Let Vantrue show you otherwise!
I've seen a lot of drivers hesitate to buy a dash cam because they assume the installation is some big technical project—wires everywhere, hours of YouTube tutorials, tools you've never heard of…
But honestly? It's way easier than most people think.
Modern dash cams are designed so anyone can install them—no tech background required. Here's what the setup really looks like:
✓ Step 1: Mount it on your windshield
Find a good spot on your windshield and stick the mount on. Vantrue dash cams use magnetic mounts, so you can easily attach or remove the camera without messing with the whole setup.
✓ Step 2: Plug it into your 12V outlet
This is your power source—simple as that. If you just want quick and easy power, you're done here. No hardwiring is needed unless you want extra features like 24/7 parking mode.
__________________
Old Nov 17, 2025 | 03:49 AM
Vantrue's Avatar
Vantrue
PREMIUM SPONSOR
✓ Step 3: (Optional) Tuck the cable
Run the cable along the edge of the windshield for a clean look. Vantrue dash cams include a crowbar tool to help with this, but honestly, your fingers work just fine too.
✓ Step 4: Start your car
Vantrue dash cam powers on automatically when your engine starts. It'll begin recording right away—zero extra steps needed.
✓ Step 5: Adjust a few settings
Set your resolution, GPS, WiFi, or parking mode. You can even finish all the setup through the free mobile app, which makes things even easier.
And that's it. The whole process usually takes under 10 minutes.
Old Nov 17, 2025 | 03:50 AM
Vantrue's Avatar
Vantrue
PREMIUM SPONSOR
If you want a more advanced setup (like hardwired parking mode), the kits are straightforward and much simpler than they used to be.
Bottom line: Installing a Vantrue dash cam is not a headache. It's quick, simple, and absolutely worth it for the peace of mind.
Here's an exclusive discount code for our forum members — it can be stacked with Black Friday deals: 2025IBVTALL5
If you're unsure which dash cam to choose or need help setting one up, feel free to drop your questions—we're here to help!
