Vibrant Exhaust Systems for Neon Owners
Old Feb 15, 2006 | 03:43 PM
VerociousMotorsports's Avatar
Default Vibrant Exhaust Systems for Neon Owners
New for '06 we have Vibrant Performance Exhaust Systems available for Neon Owners!
*Please note: We are in the process of getting these items up for sale online, if you don’t see them in our store when you go to make a purchase, please call to speak with one of our sales representatives to place your order. 302.472.0601
Part #1631
2003-2005 Dodge Neon SRT-4 Turbo-back system
Tubing O.D.: 76mm (3 in.)
Tip Size/Style: Dual 4” Round, angle cut
Notes: System includes Downpipe with Metal Cat
Features of STREETPOWER Cat-Back/Turbo-Back Exhaust Systems
• 100% Stainless Steel Construction
• All Vibrant STREETPOWER exhaust systems are made using 1.5mm thick T304 Stainless Steel tubing for superior durability and better exhaust resonance control than can be provided by thinner wall tubing. Tubing is CNC Mandrel Bent for unrestricted exhaust gas flow.
• STREETPOWER cat-backs exit into a large, oval body “True Straight Through” rear muffler that is specially selected for each application for optimum exhaust tone control. Most systems also feature an inline Stainless Steel resonator to further assist in producing a pleasantly low and deep exhaust note. All STREETPOWER rear mufflers and resonators are densely packed with premium sound suppression materials.
• Virtually all STREETPOWER cat-backs are 95db compliant according to SAE spec J1169 (1998)
• TIG welded at every seam for optimum weld strength
• Easy Bolt-On Installation, utilizing all stock mounting points. Comes with all hardware and gaskets.
Part #1706
1994-1999 Neon Axle-back system
Part #1718
2000-2005 Neon (excl. Neon RT) Axle-back system
Features of STREETPOWER Axle-Back Exhaust Systems
• Every STREETPOWER Axle-Back Exhaust System features complete T304 Stainless Steel construction for strength, durability, and excellent looks.
• STREETPOWER axle-back systems feature a large, oval body “True Straight Through” rear muffler that is specially chosen for each application to produce the best combination of performance gains and tone control.
• TIG welded at every seam for superior weld strength
• Designed to bolt up directly to the stock mid-pipe for an easy installation.
