Ksport Coilovers and BBK for EVERYONE
Old Oct 26, 2006 | 05:01 AM
Majormods's Avatar
Majormods
Default Ksport Coilovers and BBK for EVERYONE
I wanted to make these available for everyone! I have been selling on numerous forums with an excellent reputation and now with 50+ orders sold and still counting in only the last 4 months. I even got one for myself! Also, just as an fyi, ksport is planning on releasing an EDFC component to go with their coilover sets so these will be compareable to the Tein SS for alot less. These will be available for ALL MAKES AND MODELS so tell all your friends so they can get in on it too. If anyone is interested in running this GB on other forums, non sentra related, please let me know as I can make it WELL WORTH YOUR WHILE! You must PM me for all pricing due to ksport regulations. Btw, these msrp at $1150 and sell on average for about $900 but with me they are still ALOT LESS! Also, custom spring rates are available for only $50 additional. The ride height is between 0.5" - 3.5" adjustable of course. All past ksport owners, if you would like to chime in on your driving impression, be my guest. All payments can be via MO or paypal. If using paypal the payment address is paypal@majormods.com and any price I quote you WILL INCLUDE any paypal fees. Again, these are for ANY vehicle you may own. Now back to the product at hand!
Here are some key features:
* 36-way adjustable dampening
* Made from high quality 6061 Aluminum with T6 for increased hardness
* Compression/Rebound adjustable
* Adjustable spring perch for height adjustment
* Adjustable body allowing maximum suspension travel
* Pillow Ball Top Mount w/ adjustable camber (not available for some models)
* Monotube High Pressure Design reduces oil leakage
* Electroplated body for protection from corrosion and rust
* One Year Limited Warranty
the actual color
BRAND NEW!!! come and get em.... $2650 MSRP, on sale for unbelievable price at almost 50% off.... PM or email for the cost!
Ksport Procomp Big Brake Kit
Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
The Ksport big brake kit includes:
8-Piston Aluminum calipers
High quality brake pads
D.O.T. Compliant Stainless steel brake lines
Machined aluminum hats
Carbon steel brackets
330mm (13") large ventilated discs (17" wheels required)
Ksport SC5 street brake pads (RC1 race pads available for additional cost)
Extreme Lightweight Caliper:
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
High Performance Rotor:
Most applications utilize the 2-piece floating disc assembly which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
Ksport SC5 Street Pads:
These NAOC ceramic pads are designed to give you the optimal braking performance under street and occasional track conditions. Optimal operating temperatures are between 194°F - 1022°F for fast warm up under normal driving conditions. These pads reduce the amount of brake dust by 50% or more when compared to our race pads. The SC5 pads also greatly reduce the amount of noise and wear on the rotor over the race pads. The average coefficient of friction on this pad is between .46 and .53.
Old Oct 31, 2006 | 11:00 AM
Majormods's Avatar
Majormods
Default RE: Ksport Coilovers and BBK for EVERYONE
Well guys/girls, today is the LAST day for the sale price. Ive had alot of emails and PM's and we got 7 sets ordered as of now. Keep em coming cuz after today the price is going up at least another $100+
