need some help
I've seen size like that on Charger, it fits. the overall diamete is only 1" bigger than the OEM 18" wheel. Check the Offset of the wheel first, because you might end up needing Spacers.
However, ur car will ride like **** in terms of comfort. and when the tires goes,(blow up, worn out, ran over nail on the sidewall) the rim goes, it is painful to mount new tires on them, and requires better than conventional tire machine. Most tire shops will rather blow you out of the door than take that job.
