Wheels & Tires Discuss rims and tires here.
What is the biggest tire I can fit on a 2005 Dodge Ram 1500 Quad Cab?
Old Mar 7, 2008 | 12:57 PM
metfan34's Avatar
metfan34
Default What is the biggest tire I can fit on a 2005 Dodge Ram 1500 Quad Cab?
What is the biggest tire I can fit on a stock (no lift etc...) 4X2 2005 Dodge Ram 1500 Quad Cab with no problems? (rubbing etc...) thanks
Old May 4, 2008 | 09:14 PM
RedneckDodge86's Avatar
RedneckDodge86
Default RE: What is the biggest tire I can fit on a 2005 Dodge Ram 1500 Quad Cab?
You can fit 33" but if you get a leveling kit you should be able to fit the 35" tires. Im sure the 2wd is the same or close to the 4wd which is what i have. You can get a 2" leveling kit for the front of your truck for 79.99 from top gun customz. It is a nice and easy kit to install that doesnt take away from the factory ride. Hope that helps ya
