Wheels & Tires Discuss rims and tires here.
How to remove plastic chrome wheel cladding
Old Mar 19, 2009 | 12:31 AM
Trophey Truck's Avatar
Trophey Truck
Default How to remove plastic chrome wheel cladding
Need advice on how to remove the chrome plastic cladding from my stock factory wheels. The plastic covers the Aluminum cast wheel and is obviously glued on. The wheels are on a 06' Dodge Ram SLT 2500, 4x4, Diesel. I tryed heating the plastic to loosen the glue but no good.
Old Mar 21, 2009 | 02:32 AM
Frenchy's Avatar
Frenchy
oh boy, I have noo idea, i was looking at this at the dealer the other day and was wondering how to get it off... maybe you have to remove the tire from the wheel?
I have no idea though...
Old Mar 23, 2009 | 11:11 AM
Trophey Truck
Default The answer to removing plastic cladding...
*Remove the wheel
*Heat the edge of the wheel from the back side, concentrate on a single area, use industrial dryer/heater.
*while wheel is upside down push the spot that has been heated, the cladding will have to be pryed off from this point, obviously use a flat crow bar with padding on it like thick tape, so you don't scatch the wheel!
*Now comes the fun part, removing the adhesive, I tryed several adhesive removers, from goof off to industrial linoleum remover, the only thing that worked was Aluminum aircraft paint and decal remover from Kragen. If you are interested, can email me for the name, I cannot think of it at this time. Several applications were needed after sitting on wheel for 10 minute increments and washing in between applications...
*The result was worth the whole weekend of work... to reveal those really great looking Aluminum wheels, I then painted my plastic caps a flat black!
Old Apr 2, 2009 | 01:50 PM
ramman8's Avatar
ramman8
i cant get the tires off the truck , do i have to remove the chrome plastic first or is there a special wheel lock? its on my 2008 ram 1500 slt cre cab 4x4 big horn . thank you
