Wheels & Tires Discuss rims and tires here.
Seriously bulging tire!!
Old Aug 5, 2012 | 01:26 PM
Blueball's Avatar
Blueball
Default Seriously bulging tire!!
Why would this happen?
I have one other tire that shows 'cupping' .. like this one did ... now this one is TOAST!
Old Aug 5, 2012 | 01:33 PM
Blueball's Avatar
Blueball
[URL=http://imageshack.us/photo/my-images/803/img20120805131813.jpg/]
These tires are only two years old.
They are Falken Z04 S/T
275/45/R20
Two are in great shape ... this one is toast .. one other is questionable
Any replacement recommendations?
2003 1500 Reg cab 2wd ... 20" Rims
I already have a set of Pirelli Scorpion STR's that I use for winter. So I only need summer tires.
Old Aug 5, 2012 | 01:35 PM
Blueball's Avatar
Blueball
Old Aug 5, 2012 | 02:53 PM
Blueball's Avatar
Blueball
What is the widest tire you would recommend for my truck. I like the wide look ... plus they generally have a higher load rating. I don't mind a slightly lowered look either.
I'm looking at 305/50/20 .. Yokohama Parada Spec-X
Old Aug 5, 2012 | 09:28 PM
Blueball's Avatar
Blueball
any help?
Old Aug 7, 2012 | 08:25 PM
Blueball's Avatar
Blueball
bumpy
Old Aug 27, 2012 | 12:54 PM
Blueball's Avatar
Blueball
replced them with Yokohama Parada Spec-X 305/50/20
They have a seriously wider stance now.
Also, so much grip that I can't spin them at all!!!!
Old Oct 31, 2012 | 03:54 PM
Plainbroke's Avatar
Plainbroke
you ran over something in the rode and broke a belt. or have been over inflated for the weight on them. Just because the side wall says 65psi max does not mean you should run that.. I vote for the run over something on the highway.
Old Nov 5, 2012 | 10:47 AM
David William's Avatar
David William
Default my new Holden Barina Tires has got similar problem......help....
replced them with Yokohama Parada Spec-X 305/50/20.....this sort spots may due to over run in high ways.... i am going to vote for this... most of the i have to face problem with my Barina car tires.. i just cant understand what wrong with those tires... Recently facing another problem with this tyre...
My back right Tyre is making a clunk noise and everytime i drive it something bangs from side to side i did have my wheel bearings replaced recently but now its got worse also out of nowhere it makes a loud sharp screaching noise what could this be plz help .. you can suggest me to over come this kind of situation ............
holden barina
Old Nov 13, 2012 | 03:53 PM
thegr8witewedge's Avatar
thegr8witewedge
I used to work in the tire biz and that is a slipped belt. This may be a failure in materials and craftsmanship, though you may have a hard time proving to the manufacturer that is the case. I have seen this on really old tires and really cheap tires the most. Rarely, but not unheard of, have i seen it on quality brand name tires. I am sure it's too late, but a tire like that, inside its warranty, can be warrantied by the manufacturer through the tire dealer you bought them from.
