Wheels & Tires Discuss rims and tires here.
Bad Vibes at Freeway Speeds
Old Aug 21, 2020 | 07:23 PM
bcuda's Avatar
bcuda
Default Bad Vibes at Freeway Speeds
My '03 Ram 1500 4x4 Laramie Quad Cab has a bad vibration starting at 65+ (mph).
It's definitely a "lower frequency" vibration similar to a tire out of balance as opposed to driveline which is a much higher frequency.
Rotated the tires - no change.
Rebalanced the tires- no change.
Replaced the tires with new Michelins - no change.
Replaced the wheels - no change.
If it's not the tires or wheels, then what else could be causing the bad vibes?
Old Mar 2, 2021 | 07:11 PM
b2benedict's Avatar
b2benedict
Did you find the problem and can you post please?
Old Jul 8, 2021 | 10:26 AM
nialsens's Avatar
nialsens
Yep, those are not probably an issue with wheels and tires. They are most likely caused by faulty CV axle or bad engine mounts.
