2005 2wd Largest Tire Size Fit? 2500
I have a 2005, 2 wheel Drive, Quad cab, 2500. I am going to put a Front end leveling kit on. The kit is approx 2" Lift (I hope). What is the largest size tire I can fit? What Rim do I have to use? Is the Stock rim OK or will the tire Rub. I would like 35"s. But I think that 33s are probably all that can fit. I am looking for a BFG Alterain or similar tire.
[IMG]local://upfiles/20357/ADE1BDF90C854011B5034BCB179A2D56.jpg[/IMG]
I have not tried it myself, so anyone with previous experience who knows otherwise, feel free to jump in, but with a moderate lift like that, I would not be confident of a 35 fitting. The stock tire is about 31" diameter, so 33 has a decent chance of working, although if your kit only lifts the front, there's a chance you might rub on the back if you really load the truck down.
