Wheels & Tires Discuss rims and tires here.
265/75/16's on 97' Ram 2wd stock rims?
Old Aug 20, 2006 | 10:55 PM
iamkidc's Avatar
iamkidc
Default 265/75/16's on 97' Ram 2wd stock rims?
I currently have 245/75/16's, but was wondering if 265/75/16's will fit on 97' Ram 2wd stock rims without rubbing in full wheel lock?
Old Aug 20, 2006 | 11:07 PM
badboy22's Avatar
badboy22
Default RE: 265/75/16's on 97' Ram 2wd stock rims?
well if the rim size is 16 and reg tire is 75 they would mount on there only thing you would have to really worry about is clearence under the wheel well turning i had a ford 150 4x4 stock went from 16 75 put 265 on with no problem just gas mileage ,
Old Aug 21, 2006 | 02:33 PM
iamkidc's Avatar
iamkidc
Thanks, I just ordered a set of Dayton Timberline L/T 265/75/16's.
Old Aug 26, 2006 | 03:30 AM
Sinister's Avatar
Sinister
you can adjust your steering bolts to prevent full wheel lock rubbing., i just had to recently going from 265s to 285s.. its quite simple and only takes two 9/16th wrenches.
Old Sep 23, 2006 | 10:32 PM
livinginh's Avatar
livinginh
I have 265x75x16 under my 97 2wd and I have no problems what so ever, but I have noticed mine seems to sit higher then most other 2wd's, not sure why.
Old Sep 24, 2006 | 05:18 PM
junkman306's Avatar
junkman306
I've got 255/70's on my 95 2wd ram and I got lots of room.
