Wheels & Tires Discuss rims and tires here.
TPM Question on my R/T? HELP!
Old Oct 3, 2006 | 12:59 AM
RadrussR/T's Avatar
RadrussR/T
Default TPM Question on my R/T? HELP!
I found a new set of rims for a good deal , I want them to replace on my 07 caliber R/T Stock crom Clad Rims that are 18x7. My car is equiped with the Tire Monitor System, will the sensors work with any wheel, I believe its the valve stem sensor, and the wheels I want are 18x7.5 just black and I using stock tires??????????
Old Oct 3, 2006 | 12:51 PM
Ben@tirerack's Avatar
Ben@tirerack
Default RE: TPM Question on my R/T? HELP!
Excellent question! The valve mounted sensors do not work with every wheel. The angle of the valve stem, the size of the valve stem hole, and the contour of the bead seat and are the main factors. So check with the vendor of the wheels before purchasing to see if they will accept your sensors.
