Wheels & Tires Discuss rims and tires here.
air????
Old Oct 18, 2006 | 03:29 PM
1 cowboy's Avatar
1 cowboy
Default air????
hi i have a 1997 ram 1500 the tyres on the front are P235/70R16 THE REAR LT 235/85R16, Could someone tell the tyre pressure on these PLEEASE, there are no markings on the truck to say what they should, it would be unladen, thanks in advance, mitch
Old Oct 18, 2006 | 04:33 PM
Ben@tirerack's Avatar
Ben@tirerack
Default RE: air????
Do you have a 1500? 2500? 3500? What load range are the tires?
Old Oct 19, 2006 | 09:50 AM
1 cowboy's Avatar
1 cowboy
Default RE: air????
ORIGINAL: Ben@tirerack
hi Ben i have 1500, and the only info i can find on the tyres is, apart from the above is, 2ply 40 psi MAX and (104S) and a circled E4 max load 900 kg
AND ON THE REAR Load range E max 80 psi cold, thanks again, Mitch
Old Oct 23, 2006 | 04:34 PM
Ben@tirerack
Default RE: air????
Looks like you said 1500 the first time That's kind of an odd setup to have on that truck, different sizes and load ratings. I'd run at least 35psi all around, Dodge recommends 41 psi on those smaller sizes (similar to the front tire) but the tire only takes 40. when you change tires, I'd probably do something like a 245/70 all around.
Old Oct 23, 2006 | 11:31 PM
1 cowboy's Avatar
1 cowboy
Default RE: air????
i did think it strange to have smaller tires on the front ,thanks for the advice,, mitch
