Wheels & Tires Discuss rims and tires here.
'04 Ram 1500 Quad Cab 4x4 with 4" Lift
Old Oct 19, 2006 | 07:35 AM
wsbbx080's Avatar
wsbbx080
Default '04 Ram 1500 Quad Cab 4x4 with 4" Lift
Hello,
I would like to know the best tire and rim size on '04 Ram 1500 Quad Cab 4x4 with 4" lift kit. Manufacturer of the lift kit (SuperLift) recommends up to 35x12.50 (tire) with 4.625 B.S (rim).
I am thinking putting 20" rims and there are some 35x12.50R20 tires (Toyo M/T, Nitto Mud Grappler, ProComp X-M/T...) available. But, how about 35x13.50R20 tire (ProComp X-A/T) and 325/60R20 tires (Toyo A/T, Nitto Terra Grappler...)
I also would like to know the best rim width for this truck.
Thank you.
Old Oct 20, 2006 | 09:00 PM
nathanp's Avatar
nathanp
Default RE: '04 Ram 1500 Quad Cab 4x4 with 4" Lift
id personally go with a 10" rim and then go with a 15" wide tire, obviously if u are lifting it and putting that big of tires on you want to use it offroad, and going to a 15" tire makes quite the improvement in the mud, just make sure you are geared correctly to run them big tires
