Wheels & Tires Discuss rims and tires here.
Lug Nut Torque?
Old Nov 6, 2006 | 04:59 PM
flash9's Avatar
flash9
Default Lug Nut Torque?
What is the recommended Lug Nut Torque for a 2005 Caravan Alloy Wheels?
Old Nov 6, 2006 | 07:12 PM
Ben@tirerack's Avatar
Ben@tirerack
Default RE: Lug Nut Torque?
Dodge spec is 85-115 ft.lb.
Old Nov 6, 2006 | 07:17 PM
flash9's Avatar
flash9
Ben,
Thanks for the reply.
Quick question: It seems to me that 85-115ft-lb is a wide range. Since I have a torque wrench, what should I set it to? I know that tightest is not alway the best.
Thank you.
Old Nov 10, 2006 | 08:59 PM
Ben@tirerack
I'd go right in the middle 100ft. lb. That way you have the most cushion on both sides in case the wrench isn't perfectly accurate or anything small errors like that.
