Wheels & Tires Discuss rims and tires here.
Old Aug 10, 2015, 07:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
Ram Wheel and Tire FAQ
Old Dec 26, 2008 | 04:07 PM
RAMSLT4.7's Avatar
RAMSLT4.7
well when i was getting my lift kit the people who did it said i needed a offset of 5.5 inches or greater if that helps you out any
Old Mar 14, 2009 | 01:38 PM
object16's Avatar
object16
Default Dakota 2008 4x4 is 235/85/16 OK?
Hi, the stock goes up to 265/70/16 the 235 is 31.7 inches tall - would that cause a problem.
Old Apr 1, 2009 | 04:28 AM
mactate131's Avatar
mactate131
Default Got the tires I was asking about!!!!!!
I now have new ProComp shocks, Edge Juice with Attitude and 35X12.5X17 Dick Cepek FCII tires on my original wheels. I also added a MagnaFlow 5" exhaust on it so far.
The only rubbing I have is in reverse at full lock.
Now for some other questions I'm really hoping for more feedback on.
I have the following in line for very near future upgrades. It all started with my wanting better gas mileage last year when the prices were sky high. After a year of reading and dreaming I'm now finding myself ready to put so much money into my truck that I could go get a motorcycle, jet ski and wicked stereo.
But the power I find myself dreaming of sounds so frickin fun I just want to go ***** out. Plus I work one block from ATS...
So I'm in serious talks with ATS and near ready to make some big decisions with new upgrades that include the following:
Propane Injection
Changing Gears from 373 to 411
4000 Aurora Plus
50HP injectors
T6 transmission (TC & VB & Input/Output & Flex & Inter. etc..)
This will cost so much I would like to consider saving money for a new sweet stereo system. So the question is this.
What would be the most important things in your opinion if you had to choose?
According to what I have heard so far I should start with these in order.
Gears
Propane
Transmission
Turbo
Injectors
Stereo just to make it ssoooo much more fun................
Old Jun 1, 2009 | 01:33 AM
oscarjr27's Avatar
oscarjr27
Default Can i go smaller on my rim?
I have 20 inch rims on my truck that are stock. And I wondering if I can go smaller to a 17 or 18 inch rim?
Old Jun 3, 2009 | 02:46 PM
bigmac18's Avatar
bigmac18
Yes you can. But no smaller than 17" due to the size of the calipers.
Old Apr 28, 2010 | 04:02 PM
gevalco207's Avatar
gevalco207
Propane Injection
4000 Aurora Plus
50HP injectors
Gears
Propane
Transmission
Turbo
Injectors
I would think gears would be your best best. get the gearing right then do hp.
Old Aug 2, 2010 | 05:55 PM
tre2whi's Avatar
tre2whi
I have a question well i just bought a set of 17' factory dodge rims and tire for my 99 dodge ram 1500 2x4 but when i went to install them the rear whells fit but the fronts would not ? what do i need to do to fix this ?
Old Dec 16, 2010 | 03:45 AM
toyhaulersdream07's Avatar
toyhaulersdream07
This is great post thanks for the data, especially since I am getting new tires after the 1st of year and am going up in size w/ the use of of leveling kit and I will be using the stock wheels for now
Old Jan 10, 2011 | 11:53 AM
hemigirl20's Avatar
hemigirl20
alittle help here guys pls, i have an 08 1500 quad with 20" wheels, the inside door jam has p275/60r20 but the tires on it are lt285/65r20, my question is tire pressure i know they say follow whats on the door tag but when they were at 35psi the tire sensor indicator was on, the tire max is like 80psi so what do i use to get the best wear, gas mileage etc.
Old Jan 23, 2011 | 08:38 AM
HammerZ71's Avatar
HammerZ71
Door jam sticker is basing that on stock size and load range tires. You run the "E" load range tires that are on your truck that low and they will wear very quickly and cost you big time fuel economy. A light truck tire with a max cold PSI rating of 80# is an "E" load range tire.
My rule of thumb is to run a tire at between 75-80% of the maximum PSI listed on the tire, which in your case would be in the 60 psi range. But be forewarned, an "E" load rated tire is really a tire for a 3/4 & 1 ton truck and really is a high load tire for a 1500 Ram. With 60 psi in them they are going to ride harsh, as a high load tire should.
Start with the 60 psi in them and go down on the air if the ride is too harsh, but remember, the lower you drop the air, the faster the tire will wear and the worse your fuel economy will be.
Unless you tow/haul real heavy (like over the capacity of a 1500 heavy) you should be looking at a "C" load range or "D" tire at most when you replace these tires. They will ride much better on a 1/2 ton truck...
