Wheels & Tires Discuss rims and tires here.
Anti-seize on lug studs?
Old Jan 28, 2007 | 11:14 PM
89Daytona's Avatar
89Daytona
Default Anti-seize on lug studs?
I saw this note on your tech website and was wondering why you say not to put anti-seize on lug hardware or studs. It makes removing the lugnuts a lot easier, and I have never had any problems with wheels becoming loose because of it being applied to the stud threads.
"NOTE: We suggest removing the wheel and applying a thin coating of "antiseize" around the axle hubs to help prevent rust and permit easier removal when it's time to rotate your tires. Do not apply "antiseize" to the lug hardware or studs"
Old Jan 30, 2007 | 08:03 PM
Ben@tirerack's Avatar
Ben@tirerack
Default RE: Anti-seize on lug studs?
Antiseize makes it nearly impossible to accurately torque the lugs. Its lubricating effects allow the lugs to be tightened further than they should be, which can lead to uneven torque among the studs, overtorquing, and potentially damage to the wheel or studs. It is not the end of the world, but it is definitely not optimal.
Old Jan 31, 2007 | 11:09 PM
shnormo's Avatar
shnormo
Better off just using penatrating oil right before you bust them off. Then hit it with some brake cleaner to remove the oil before your retighten them.
Old Feb 5, 2007 | 01:03 PM
mazdab2600's Avatar
mazdab2600
not on the studs but on the face of the rotor/drum for the aluminum/cast rims just a thin coat
Old Feb 23, 2007 | 10:59 PM
98Dodger4x4's Avatar
98Dodger4x4
Thats what I do I put it on the rims so they can come off easy. On the lugs isn't a good idea
Old Jul 3, 2007 | 01:29 PM
bdhuntr's Avatar
bdhuntr
Aircraft wheels use Lubtork (Mil-T-5544; SAE AMS2518) on the tie bolts that secure the wheel halves together, which is an anti-seize compound. Butthe torque value is compensated for its usage, as it is actually called a Lubtork Value. Torques followed by the letter "L" such as in "torque to 135-145 Lin/lbs" indicate the usage of Lubtork, whereas the letter "D" indicates a standard dry torque value.
Why this cannot become an automotive industry standard escapes me. It makes it much easier to remove lug nuts.
