Wheels & Tires Discuss rims and tires here.
07 20" ram wheels on 05 Dakota
Old Mar 9, 2007 | 03:05 AM
LB's Avatar
LB
Default 07 20" ram wheels on 05 Dakota
I am gettin some chrome 07 20" ram wheels newtruck takeoff's (will trade for silver painted 20's if anyone is interested? they will match my truck) Goodyear 275/60/20tires are for sale as well, less than 50 miles.
Does anybody know the offset of the factory 16" dakota wheels vs the 20" RAM wheels?
I hate it when they stick out of the fenderwells.
Also I am looking at 265/50/20 or 285/50/20 for tire size with a 2" front leveling kit.
Anyone with expercience/input on this?
Thanks,
LB
Old Mar 15, 2007 | 02:55 AM
tecdady's Avatar
tecdady
Default RE: 07 20" ram wheels on 05 Dakota
i have the same question as this guy, but mostly what i need to know about putting 20's on my '05 dak. what size tires if any i should put on there that will be close to the stock height as whats on the 16's now. lots of great info on here about the rams but not much for daks. any help is appriciated.
-chris
Old Mar 16, 2007 | 04:49 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
https://dodgeforum.com/m_353736/tm.htm
https://dodgeforum.com/m_609415/tm.htm
https://dodgeforum.com/m_722441/tm.htm
All 3 posts have 3rd Gen Dakotas on 20" wheels, be it Ram wheels or aftermarket. These should answer your questions...
Tire size on a 20" wheel on a Dakota will be 275/45/20.....
Old Mar 17, 2007 | 01:41 AM
LB's Avatar
LB
265/50/20 are almost identical to my stock 265/70/16's
285/50/20's are about 3/4" taller and 3/4" wider than stock, this is what I am going to use with a 2" leveling kit.
I have also found most 285/50/20's are cheaper than the 265's, not sure why other than 265 may be more popular (Les Schwab Proxo's)
Here is a great calculator to compare stock to modified.
http://www.miata.net/garage/tirecalc.html
Since the first post I have sen many pictures of ram 20's on the dakota and they look GREAT! offset si only 1/4" difference.
LB
Old Oct 25, 2008 | 10:35 AM
dwidrick1's Avatar
dwidrick1
Default dakotas with ram 20's
can you post some links to the pics of these dakotas with ram 20's?
thanks
