o2-sensor positions? (picture)
Hi again!
Yes I know, I'm very thankful for that.
But what does your manual say about error code P0134 = Bank 1 Sensor 1? Could you scan a page in the manual and post the picture here or tell me the exact info that your manual describes? Or where the sensor (Bank 1 Sensor 1) is located?
Because the Chrysler Cirrus has the exact same engine and the Dodge Avenger 2.5 also has the same cylinder 1 position, I guess P0134 means the sensor located rear of the plenum? (close to the firewall)?
Thanks in advance.
Best regards
Thanks in advance.
Best regards
Excuse me but you do realize that just because 2 different vehicles have the same engine does not mean that everything is the same on those two vehicles.
For example I own a 1991 Mazda RX-7. My brother in law owns a 1986 Mazda RX-7. Both engines are 6 port engines. My engine uses the airpump back pressure to activate the 5th and 6th ports. His does not. Both are 1.3L Rotary engines.
Badvenge has told you exactly which sensors are what earlier and he DOES have the right manual and has been working on Avengers longer than most so I would just follow the info that he told you earlier or have a mechanic work on it like he stated...
Hi again!
Okey, maybe cylinder 1 is different on the Avenger compared to the Cirrus, but how likely is that? Have you ever popped the hood on a Cirrus? They look the SAME!
I guess I follow badvenge's manual and replace the sensor in front of the car (Bank 1 Sensor 1 is right in front of you when you open the hood or lie down on the ground I guess?).
Thanks in advance.
Thanks in advance.
Hi!
I have read more and more on the Internet and everyone says different things:
http://www.asog.net/smf/index.php?topic=2436.0
http://www.justanswer.com/dodge/1cf2...nk-sensor.html
