My first 1st Gen Dak.. Some questions
Old 07-03-2016, 11:21 AM
Moosetank's Avatar
Moosetank
Moosetank is offline
Default My first 1st Gen Dak.. Some questions
Hello Everyone!
My name is James - just moved from Texas to Virginia a few weeks ago and after getting here and running through Craigslist daily I found a steal..
1993 Dak LE CC 3.9 v6 auto - $300 cash.
truck runs and can drive but needs a brake line to the rear and the rack and pinion needed replaced..
so on Friday I decided I'd yank out the rack and go grab one over this weekend but when attempting to remove it.. it yanked the entire steering shaft out.. it was seized together by rust.
so I have been searching as hard as possible to find a steering shaft online but no luck... so yesterday I went to work and busted my *** to get it unseized... so I got the top section of the steering shaft off and slid back up through the firewall back to the steering wheel but the lower section is garbage..
so does anyone know where you can find the lower steering shaft??
I know junk yards or a fab shaft but just seeing if there is a manufacturer that builds them..
Attached Thumbnails My first 1st Gen Dak.. Some questions-img_20160703_092417.jpg   My first 1st Gen Dak.. Some questions-fb_img_1467409486968.jpg
Old 07-03-2016, 02:00 PM
djibara's Avatar
djibara
djibara is offline
Did you check Rock Auto?
Old 07-03-2016, 08:36 PM
robertmee's Avatar
robertmee
robertmee is offline
They're not on rock auto...dorman makes a lower for gen iii but I don't think anything exists for gen I aftermarket. Should be able to snag one in a junk yard...87 to 95s all used the same lower part number looking at moparts.
Old 07-03-2016, 09:01 PM
Moosetank's Avatar
Moosetank
yeah that's what I'm thinking.
there is a local yard that has 2 daks out there.. gonna go check them out.
Old 12-30-2016, 10:03 AM
Toyota_Concept's Avatar
Toyota_Concept
Toyota_Concept is offline
2017 Toyota Tacoma Pick-Up Concept, Release, Price. FRA-tuned FOX Internal Bypass shocks give you the ultimate in performance and control. Comes with a 2.5-in aluminium housing, hardened, oversize shock shafts and remote backup available in the back...
http://www.toyotaconcept.net/wp-cont...se-600x300.jpg
http://www.toyotaconcept.net/2017-to...and-price.html
Quick Reply: My first 1st Gen Dak.. Some questions
