Wheel cylinder nut size.
Old 09-02-2015, 09:56 PM
tmaxx00's Avatar
tmaxx00
tmaxx00 is offline
New Member
Question Wheel cylinder nut size.
I need to know the mounting nut size for a rear wheel cylinder on a 1994 Dodge Dakota. I've tried metric and standard wrenches and can't seem to find a size which fits.
Old 09-02-2015, 10:49 PM
jkeaton is offline
Dodge Forum Administrator
Must be rounded off if neither a metric or standard will fit. There's really nothing else size wise left.
Old 09-04-2015, 01:42 PM
93 ragtop's Avatar
93 ragtop
93 ragtop is offline
I tend to agree with Jkeaton on this. Another possibility is rust over time has decreased the size of the bolt head. Bottom line is you will have to force it out with something, ie visegrips etc. Worst case, a torch. Or buy a new or used backing plate
Old 09-07-2015, 10:19 PM
tbugden's Avatar
tbugden
tbugden is offline
I don't remember what size it is but I do think that on at least one I had to hammer on a size smaller socket because the bolt was corroded. Find the closest (6 POINT!!!) socket that won't quite fit the bolt and hammer it onto the head. IF you can get it all the way on I'll bet you'll be able to turn it right out.
Quick Reply: Wheel cylinder nut size.
