Check Engine Code 27, '93 Dakota 4x4
Hello all! I recently checked the codes on my '93 Dakota, and I learned my injector control circuit is failing! I notice a lack of power and a rough idle, and I'm assuming that's a result of this code. What could be causing this code, and how do I go about fixing it? I'm assuming just switching the injectors won't fix this.
My truck is a '93 Dakota LE 5.2L 4x4. Thanks for your help!
You may assume wrong. Code 27 is often caused by a bad or clogged injector. To troubleshoot:
http://troubleshootmyvehicle.com/chr...el-injectors-1
How to fix
