Passenger window goes down but won't go up
Old 08-04-2011, 09:58 PM
johnharvard78's Avatar
johnharvard78
johnharvard78 is offline
Originally Posted by Bimmer
From what I'm being told, is that the brushes inside the motor have worn down to the point where they are not longer making the same contact on the windings as they were when it was new. This reduction in contact equates to a reduction in current flowing from the motor slowing it down. It's weak. The only recourse is to replace the brushes or most likely the cheaper route, unless you can do that yourself is to replace it. I found on RockAuto.com the complete motor AND regulator assembly shipped for $70. Not a bad price for new parts.
Thing is, that window that's giving me issues had the motor replaced with a new one, 6 months ago.
  #32
Old 08-05-2011, 12:16 AM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
It is usually a bad motor or bad master switch. You can unplug the master switch and use a jump wire to raise the window if the motor is good until you get a new switch, if it doesn't raise then you have a bad motor.
  #33
Old 10-27-2011, 07:38 AM
griffisiii's Avatar
griffisiii
griffisiii is offline
My passenger power window works with the passenger button perfectly. It only will go down with the driver button. Not up. Any simple cheap fix?
  #34
Old 10-27-2011, 10:02 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
unforunately, no it soundsl ike the master switch panel is shot (the panel in the drivers door)
  #35
Old 10-27-2011, 01:29 PM
griffisiii's Avatar
griffisiii
I took out that piece and sprayed it with contact cleaner and wire brushed the contacts. Condition has not changed.
  #36
Old 10-27-2011, 07:08 PM
hydrashocker
Time for a new switch or rebuild it if possible.
  #37
Old 10-27-2011, 09:04 PM
shrpshtr325
THE ULTI-MOD
yea as i said before the switch panel itself needs to be replaced, not cleaned REPLACED, you could get one in a j/y if you can find one there that matches your truck (or maybe swap the controls to the panel from your truck)
  #38
Old 02-27-2013, 05:43 PM
LauraM's Avatar
LauraM
LauraM is offline
I am having the same issue with Avenger Passenger window...I just hate to buy parts I may not need. Someone mentioned the "regulator" in the window?????
  #39
Old 02-27-2013, 08:08 PM
that_guy's Avatar
that_guy
that_guy is offline
If your having an issue with the power window on an Avenger you'd be better off posting your question in the avenger section, since the parts are most likely way different between the Durango and the Avenger.
Here's a link to the Avenger section for you.
  #40
Old 08-02-2013, 08:16 PM
babycakes80's Avatar
babycakes80
babycakes80 is offline
Default power windows 2004 durango
I have a 2004 Durango, the rear passenger window will go down, but not up from its own door switch. It will go up, and down, no problem from the drivers side master switch..........so, my questions is: What do I check to see why it won't go up from its own door switch? I don't think it would be the motor because it goes up and down no problem from the divers side. I would like to fix it my self? please help!!!
Quick Reply: Passenger window goes down but won't go up
