Last edit by: IB Advertising
Browse all: Cooling System
- Dodge Ram 2nd Gen How to Replace Radiator
Step by step instructions for the do-it-yourself repairs.
Help!! radiator removal
On my 2001 you can remove the brace across the top between the front fenders (it has the hood cable attached and 6 bolts) and pull the radiator out. I have the a/c condensor and an oil cooler in front of the radiator as well and they do not require removal. The a/c condensor slips into 2 brackets on the front of the radiator with no bolt or screws at the top, there are two screws at the bottom.
One note of caution---be sure the rubber mounts on the new radiator are the same size as the old ones, on the bottom and the front where the two (2) screws go through to hold the radiator or the radiator will not line up properly.
