Flex plate question 99 Durango 4x4 5.2 VIN Y
So I am replacing the engine on my Durango, the used engine I bought came without the flex plate so I am planning on using the one from my old engine. Is it a straight pull and install or does it matter
how it goes on in relation to the distributor/timing?
What engine is going in/out? are they the same? if there both 5.2's then the flexplate should be a direct swap. The bolt holes are positioned so you cant put it on wrong. FYI the flexplates for the 5.2 and the 5.9 our different as the 5.9's flexplate has a weight on it to balance the TC and the 5.2 has the weight on the converter itself.
