4WD inop
Old 07-19-2015, 12:13 PM
brothersDurango's Avatar
brothersDurango
brothersDurango is offline
Default 4WD inop
Vehicle: 01 Durango SLT 4.7 167k
Yesterday after replacing the front driveshaft took the truck went out or a drive to test out the 4wd to make sure it still worked. Took it around the block a few times but didnt feel that it was going into 4hi or lo. Noticed the indicator lights werent coming on for any of the 3 settings. Ive checked the 20amp fuse under the hood and it is still good. Ive done some quick searches and seen people suggest the switch, TCCM, CTM, or the module on the TC itself for this issue.
Before I start swapping parts if there anything i should be checking?
Old 07-19-2015, 12:58 PM
that_guy's Avatar
that_guy
that_guy is offline
Not sure about the electronics, but you shouldn't be driving in lock on dry pavement anyway, you'll break something if you do.
Old 07-19-2015, 02:30 PM
brothersDurango
Around the block is less than a half mile. It was a lot of stop and go to see if it was engauging or not but wasn't.
Old 07-19-2015, 07:00 PM
JeeperDon's Avatar
JeeperDon
JeeperDon is offline
It breaks in 5' if the situation is right, and it gets right really quick on pavement. You can test it on pavement if you know what you are doing, but just coasting at 1 mph for 10'.
Old 07-19-2015, 08:41 PM
Strocket's Avatar
Strocket
Strocket is offline
Regardless of what may or may not break something his 4wd still isn't working.
Other than checking your fuses and relays the only other way to troubleshoot the problem would be to break out the schematic and checking for shorts or a break in the circuit. Replacing parts until you fix the problem is for rookies Be a man and use your meter instead!
Double check to make sure you didn't miss a relay or fuse first.
Old 07-19-2015, 09:46 PM
brothersDurango
Ill check it again tomorrow to make sure I havent over looked something. Its not my truck (hense the name) and well I know jack about dodges or 4wd's. Just trying to help my brother out with it since the only thing he knows how to do is change the oil.
Quick Reply: 4WD inop
