Issue with trailer lights/plug
Old 09-04-2015, 10:57 PM
Limits's Avatar
Limits
Limits is offline
Default Issue with trailer lights/plug
I have a 99 Durango that I use to tow my boat/trailer.
Recently, I started experiencing issues where when I turn the left turn signal on, both lights on the trailer including the running lights flicker.
I replaced the plug on the Durango and i'm getting an intermittent flow of ~10 volts to the left turn lights, but i'm also picking up .25ish volts to the right side as well. The result is flickering lights all around the trailer.
When i turn the right turn signal on, the same thing, with the lower voltage going to the left side of the trailer.
Interestingly, i have no break lights at all.
Any advice on where I should start trouble shooting would be greatly appreciated!
Old 09-07-2015, 09:43 AM
JeeperDon's Avatar
JeeperDon
JeeperDon is offline
Is it the factory tow package, or some aftermarket setup?
Old 09-07-2015, 06:18 PM
Moparite's Avatar
Moparite
Moparite is offline
X2! Also may add how many terminal plug is on it. Does the trailer have electric brakes?
Old 01-04-2018, 08:12 AM
Cora Evans's Avatar
Cora Evans
Cora Evans is offline
We have a 2001 Dodge SE 3.3L Flexfuel with an excessive amount of miles. We still have the engine light on, well, it comes and goes. Same code, referring to the EGR valve. Which we replaced, along with every single sensor possible. It stayed off for a week, then BAM, right back on. Nothing could be found, but the code was still there. Last night, my van wouldn’t turn over. It’s like it wasn’t getting gas. (Yes I had gas, and the pump is working fine) we lifted the hood, and there was exhaust coming from the area where the EGR casket is linked with the tube. So we are assuming the tube needs replaced. If only we could actually find it. Because it seems it’s available for every vehicle but ours.
Old 01-04-2018, 10:32 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
Is this on a durango? I don't even see an option for the 3.3???
Old 01-04-2018, 10:52 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
not a durango, but if he responds with the right vehicle we can move it to the right section for him.
SE also wasnt a trim on the durango at least not for 1st generation
Quick Reply: Issue with trailer lights/plug
