Wiring 2 Alternator's
I am in need of some expert advice. I have a 98 Dodge Durango SLT 4x4 5.2l engine. I am adding a second alternator to supply my battery bank for my audio. I have the Alternator mounted and mounted another stabilizer pulley with new alternator.. Belt is running in middle of all the pulleys and it runs smooth and nicely. I installed a alternator that I got off of a 99 Durango at a pull-a-part. Along with the new alternator I installed a new BWD External Voltage Regulator and a refurbished battery. When I crank my Durango my added digital volt meter wired at the battery terminals says my volts are 25.6 severely overcharging my battery. Can anyone someone help me with the correct way of wiring the external regulator alternator and battery !! what I am or have done wrong so I can get this new power supply charging like it's suppose to. Thanks for any help..
Last edited by Beechee; 01-04-2017 at 01:43 AM. Reason: Adding Missing Information
Yes sir, I do appreciate you replying to my question. If i may pick your brain a little more. I have been told and read different threads about wiring and external regulator, and I have it wire the way the diagrams and the videos say to wire it. From the regulator which has 2 wires, one wire goes to one wire on the alternator, and the other wire on the regulator goes to the other wire on the regulator except for it also has a wire attached to it that comes from the fuse panel or a 12 volt source. And from the alternator I have it wired straight to the battery, with a 100 amp fuse between the batteries and alternator..
