first time with neon need some help
first off ust wanted to say hi im new here and new to neons my girlfriend jsut bought one and im taking on the repairs for it. im not new to wrenching im a student at unoh for diesel tech so you are not talking to a total newb lol ok so the biggest problem is her gauge cluster does not work sometimes it will other times it wont if i tap the dash it may work almost like a loose connection and even when it does work the speedo does not work below 60 any ideas of what it could be if not a loose connection? i havent torn into the dash but my first order of business is to check the connection at gauges and if it has a bcm then there at the ecm
Taking the dash apart is easy. The top cover pops off (two clips in the front) and you pull it up and toward you to remove it. The cluster is held on by 4 phillips screws and it comes right off.
https://dodgeforum.com/forum/1st-gen...er-repair.html
