Dashboard light issue 96 dodge neon base
ok here is the problem. Today started car everything worked fine. Stopped came out, now the dashboard blinker lights and bright light (warning light) are on but no other lighting, this is without the headlight switch turned on. When I turned the headlights on, the speedometor, and temp gauge don't work, the blinker lights and bright light icon lights stay on in the dashboard but no other lights work or gauges
the problem. If I open the car door, the dashboard lights up correctly. everything works fine. anyone know how I can fix this or trick the car into thinking the door is open so all my dash cluster gauges will work right?
