Neon Sensor and Part Locations
Old 12-15-2010, 11:56 PM
hemi4spd's Avatar
hemi4spd
hemi4spd is offline
crank/cam sensors, bad PCM, or just bad wiring
Old 12-19-2010, 12:12 PM
Big Lars's Avatar
Big Lars
Big Lars is offline
Default no spark
ok now i have juice to the coil back center wire with key on but only for 3 seconds, then the test light goes out. I can hear the fuel pump start up. why would the elelctricity to the coil pack stop after 3 seconds, is this normal and i need to look elsewhwer for the problem?
Old 01-23-2011, 01:35 PM
chrisj_1986's Avatar
chrisj_1986
chrisj_1986 is offline
maybe a bad starter?
Old 05-11-2011, 07:03 AM
jim hallahan's Avatar
jim hallahan
jim hallahan is offline
can i change a double overhead cam head with single overhead cam head on a 1998
neon
Old 05-28-2012, 05:39 PM
me696979's Avatar
me696979
me696979 is offline
You can but I'm not for sure what all you have to do I would say you will need the engine wire harness off another 98 sohc and I'm not sure if you need to change the computer or not I've never done it but that would be my guess
Old 07-01-2013, 01:31 PM
MemeStgermain's Avatar
MemeStgermain
MemeStgermain is offline
my 98 dodge neon won't turn over but was riding fine earlier,is there a sensor or something that is keeping engine from turning over. Please help me.
Old 07-02-2013, 12:37 PM
das2123's Avatar
das2123
das2123 is offline
This really isn't the thread to ask questions. Try starting a new post in the regular section.
Old 07-27-2014, 02:12 PM
Bs90649's Avatar
Bs90649
Bs90649 is offline
Originally Posted by DOUG'SREDNEON
error code p0172? BANK 1 RICH.
Any one have a common idea or know of a common failing in neon's that brings this error code and makes the car run super rough? any help would be apreciated.
Did u ever figure out what was making it run so rough?
Quick Reply: Neon Sensor and Part Locations
