about to pick up a d150 need some answers
Old 04-30-2013, 02:54 PM
Sniper X's Avatar
Sniper X
Sniper X is offline
BTW that truck looks like it MAY have a 2in lift, but Dodges came higher in stance than more street oriented 4x4s so there's that too. Mine looks like it is 2~4in higher than my chevy which is stock but it is stock. These are 31 10.5 15s
Old 04-30-2013, 03:08 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
i don't know if you will find headers for a big block truck. i think i remember that if you can actually find headers you have to notch the frame to make them fit.
Old 04-30-2013, 04:12 PM
sls001's Avatar
sls001
sls001 is offline
Headers for a BB truck are still available.
As far as a "budget" lift - blocks in the back (bad idea since you will be stacking them) for the front you could add spring leafs. NEVER use blocks in the front.
You could also do a shackle flip in the back and gain height as well.
Old 04-30-2013, 04:17 PM
Sniper X's Avatar
Sniper X
Sniper X is offline
Who makes headers for a BB truck still? I may need some if my 400hp 383 ends up in my truck some late night!
Old 04-30-2013, 04:24 PM
sls001's Avatar
sls001
sls001 is offline
Go to summit racing:
http://www.summitracing.com/search/d...-size/6-6l-400
Headman: 79250, 79256,
Hooker: 5905HKR
Flow Tech: 13504FLT, 33504FLT
Old 04-30-2013, 04:42 PM
Turner661's Avatar
Turner661
Turner661 is offline
sick they are reasonably cheap and for the amount of room in there looks like i can even do them myself also main reason why i wanna get this truck is cause its all mechanical no computer crap telling me whats wrong i wanna actually learn and work on my own vehicle but i cant with all this computer error codes and what not
does anyone know if they are really as easy and that or do i need to do some banging and what not like the guy previously said
Old 04-30-2013, 04:46 PM
Turner661's Avatar
Turner661
yea i rather not do block and if im swaping leaf springs might aswell save $800 and get the bds 5" lift i was just wondering cause on my dakota i was able to get a inch n half lift in the front by tightening the tortion bars
Old 04-30-2013, 05:02 PM
sls001's Avatar
sls001
sls001 is offline
Cheap headers will usually require "notching" the frame especially with an RB (440). It isn't as bad with the low deck B engines (383, 400 etc)
Watch because the base BDS kit also comes with rear blocks and an add-a-leaf, you need to upgrade the kit with rear springs. If you go 5" like the BDS kit you will have steering\wandering issues. I see the BDS kit includes a steering block but the only real fix is cross-over steering.
Old 04-30-2013, 05:36 PM
Sniper X's Avatar
Sniper X
Sniper X is offline
Usually the best way to do headers is to remove the entire stock system first. Then loose the motor mounts, and jack the motor up a couple inches very carefully and stab the headers from the bottom up or top down depending on which way looks easiest. Then bolt em up and replace the bolts for the motor mounts ans fly round the block with them open to make the neighbors hate your new truck~!
Old 04-30-2013, 11:09 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Hooker: 5905HKR
Oh HELL yeah.
I must remember this!
Also, 2.5 in true duals, will make the 400 breathe pretty good.
Quick Reply: about to pick up a d150 need some answers
