dual pickup vs reg distributor which is better and why
Old 07-04-2014, 10:33 PM
lpg's Avatar
lpg
lpg is offline
Default dual pickup vs reg distributor which is better and why
my 1987 d150 360 has a dual pickup dis how does it work and would i be better to change it to a single pickup dissy the truck has a rv cam for towing nothing erratic it doesnt seem to have the power it should if i change the dissy to a 76 model single will i have to change the comp box
Old 07-05-2014, 05:10 AM
RDuck's Avatar
RDuck
RDuck is offline
Ok. Im only going to say this once.
F.O. with the dissy or dizzy.
What the hell are you? F-ing 12?
I know you can't be retarded so stop trying to show people that you are.
You talk like an idiot, people will think your an idiot.
If you are to lazy to use distributor (which is a simple word) and you must shorten it then at least have the brain power to use DIST for it.
Thank you.
P.s. Yes. Stupidity pisses me off.
P.p.s Yes. Its your turn to get pissed. I really dont care.
Just the fact people do this when the word makes them sound mentally handicapped when obviously they are not because they have a driver's license and can use a computer (or cell phone)
Old 07-05-2014, 05:20 AM
RDuck's Avatar
RDuck
RDuck is offline
Original question is a good one and I also look forward to hearing the answer.
Old 07-05-2014, 07:23 AM
charlie1935's Avatar
charlie1935
charlie1935 is offline
If I'm not mistaken the dual pickup distributor was used the lean burn system only.
I believe it used one pickup for starting only and the other one for run.
Used different timing for start and run.
Quick Reply: dual pickup vs reg distributor which is better and why
