Heater problems galore!!!
85 D250 (318, 435, D60 with utility bed ... still ).
I can't find the heater control valve under the hood or the dash (looking thru the glove box opening) and I have heat continuously, which isn't bad right now here in the foothills of CO , but I want to find it or put one in for next summer.
According to an online repair manual from my local library the valve is cable controlled but I think that's missing too.
The truck was used on a farm in S.E. CO for an unknown number of years and the owner may have just pulled it all instead of replacing it.
Thanks for any help.
Budd
Budd
If that's true, and I suspect it is because I'm having a hard time getting a consistent idle rpm setting, I'd like to put it in the correct valve as a standard choke control cable can really only pull and tends to push like a wet noodle as I found out when I changed an 88 Jeep Cherokee (4.0, Renix, 5 speed 4X4, 3.07 axles) to an open cooling system from a closed system (drops engine temps about 30 degrees).
Budd
