1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
They were turned after the lug studs were pressed in.
Why would you turn brand new rotors? I would put the front end on jack stands take the wheels of and look at the rotors while turning the axle. If it's moving out of round(side to side) you found your problem.
The rotors have to be turned because they will warp slightly after the lug studs are pressed in. The lug studs on these need a ten ton press. The rotors run as true as can be. Everything on the front end is as true as possible.
