Help with power steering hose. Please.
Old 05-24-2013, 11:51 AM
Brian in Tucson's Avatar
Brian in Tucson
Brian in Tucson is offline
Originally Posted by 00DakDan
Actually, since you're going to replace them, just cut the old tubing flush and use a 6 point socket on the fittings. Use the tubing wrench for the install.
You might want to hit them with some penetrating oil first and let it soak a bit.
Or visegrips.
  #22
Old 05-24-2013, 11:59 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
That sounds like a great Idea 00DakDan it will save you a lot of time and frustration trying to get them out as those fittings look to be rusted in good you may even need to use some vise grips.
  #23
Old 05-24-2013, 04:35 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
I'm having some second thoughts on cutting the tubing off if you snip them off ok but if using a coping saw you may get metal particles in the line by accident and into the system if you create any suction it could suck the metal inside the steering box
Just be careful
  #24
Old 05-26-2013, 01:44 AM
RyanWilson's Avatar
RyanWilson
RyanWilson is offline
I just want the nut ofg
Quick Reply: Help with power steering hose. Please.
