Polyurethane trans mount?
The ones I have are http://www.energysuspensionparts.com...eplaces1370910
Bolt range on the top (that's the widest part of the mount) is 3.272" to 4.747" . Bolt range on the bottom is one single bolt center mount, OR center of the outside on one side to center of the other side 1.5" for two bolt mount.
windows print screen
Looks like it will bolt to the transmission (my bolts are 4.75" on center) but I'll have to drill some holes in the crossmember (which isn't quite as easy as it sounds because of the crossmember design, IIRC) because my bottom bolts are 2.25" on center.
I think I might give a shot. It's not technically a transmission mount, but I think it might work.
