glasspack set up
Old 06-08-2014, 02:22 AM
Dakota2003's Avatar
Dakota2003
Dakota2003 is offline
Question glasspack set up
I have a 2003 4.7 v8 Dakota, I was going to put on a glass pack muffler. I was wondering how easy it is to install, and the best way to install it.
Old 06-23-2014, 04:28 PM
KillerKilgore's Avatar
KillerKilgore
KillerKilgore is offline
Not hard. Got one on my 3.9
I took sawzall and cut the old one out and used 2 muffler clamps to hold the new one on.
I went to parts store and got guy behind counter to lookup an OEM muffler,
Then got him to check the inlet and outlet diameter,
Then got a glass pack with same dimensions. and 2 muffler clamps.
Loud though. Be sure to put the tail pipe all the way out from under the truck or you wont be able to hear yourself think.
Kilgore
Old 06-23-2014, 06:31 PM
MoparMan1991's Avatar
MoparMan1991
MoparMan1991 is offline
Easy peasy. You'll need a glasspack with a 2.5" inlet and a 2.5" outlet. When I had my durango I just put it on with muffler clamps. I'm sure you can get a muffler shop to weld it in for cheap. You'll probably need some makeup pipe though as well, which you'll need a 2.5" I/D to 2.5" O/D coupling to connect it to either end of your exhaust..
Quick Reply: glasspack set up
