I have a 02 dakota 4x4 i have put new brakes all the way around everything is new. something that had just started is if you do anything close to a panic stop the wheels lock up the pedal pulses like the abs is work but i just keep sliding. Thought maybe the calipers were going bad again. ( i had one seize on me a few years back) so i replaced them since they are life time warranty. Also changed the sensor for abs thats in the top of the rear end a bout a year ago. It seems to be getting worse after i changed the calipers. I bleed them for a while to rule out air in the lines. I'm getting afraid to drive it almost sled into a school bus trying to stop any idea whats going on??
coming of the interstate on a off ramp as soon as u apply the brake you can feel it start pulsing pretty intense and if you apply more pressure to stop than say going 30 mph and approaching a stop sign it stops ok but anything other than that all the wheels seem to lock up
