turbo
Old 09-26-2015, 12:25 PM
1985imperial's Avatar
1985imperial
1985imperial is offline
Default turbo
running 04 3.7 5 speed stock 3:55 rear.i do pull 19 ft boat @ trailer @ times and it does fine on flat ground. now live in mountains and it struggles uphill. anyone ever put turbo onto the 3.7?
Old 09-26-2015, 12:58 PM
jkeaton is offline
Dodge Forum Administrator
I've only seen it on a 4.7. It can be done. Not cheap. I'd look into gears instead.
Old 09-26-2015, 08:29 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
the 3.55 was for economy not towing if you installed taller tires then it really sucks for towing.
So lower tires or gears or both
I've been wanting to change out my gears for 3 years now I don't tow but having the 2.5 engine it lacks power as I put taller tires on. but I don't want too much a change just to a 3.73 possibly 3.90 as I'm just a city driver.
Old 09-27-2015, 05:19 PM
Tom A's Avatar
Tom A
Tom A is offline
Section Moderator
Dodge Forum Moderator
Like they said, change the gears instead. It's cheaper, won't cause you the headaches a turbo can, and will probably give you a similar performance gain. I would even consider swapping out the 3.7 for a 4.7 before I put a turbo on it.
Old 10-01-2015, 09:11 PM
dodgeramguy85's Avatar
dodgeramguy85
dodgeramguy85 is offline
The amount of work that goes into properly mounting a turbo you would be better to swap in a v8 or sell the truck for one with a v8... Just a few items that come to mind with putting a turbo on...
Turbo
Custom pipe engine/intercooler
Custom engine tuning to run right
Mounting the turbo to the exhaust
Different intake
Injectors
Headstuds
Right there you are about 2,500-3,500
Quick Reply: turbo
