heater or ac problems under load
Old 12-21-2015, 09:50 AM
bp97Dakota's Avatar
bp97Dakota
bp97Dakota is offline
Default heater or ac problems under load
97 Dakota sport ex-cab 5.2 auto and 2 WD w/61,000 K. Need some help please. On either heater or ac, the fan cuts out when under load going up hills. When load eases it comes back on. Also, temp runs around 200, but only luke warm air comes out heater. I did check stat, but due to alternator being in the way, I could only move housing a little, I did see the side of one. Could not see if spring or valve is still there, it does seem to take forever to warm up.
Old 12-21-2015, 10:14 AM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
It's probably not a fan issue.
More likely the mode doors, that control where the air goes, are changing position when under load - it's a common problem. You run out of vacuum to keep the doors in position.
There is a check valve in the HVAC system and a reservoir. Not sure where on a '97 the valve is but it's usually located in one of the lines by the brake booster. It looks similar to what's in the attached pic.
Flush your heater core out. Take the inlet/outlet hoses off and use your garden hose to flush it. You'll be amazed at how much junk is in it - again, a common problem.
File Type: jpg
Old 12-21-2015, 10:51 AM
bp97Dakota's Avatar
bp97Dakota
Thanks much. I saw on here how to flush core. And will check and most likely change the vacuum check valve.
Quick Reply: heater or ac problems under load
