2nd Gen Durango 2004 - 2009
Car won't shift when it's cold
Old 01-04-2012, 10:17 PM
captain11's Avatar
captain11
captain11 is offline
Unhappy Car won't shift when it's cold
I have a 2008 Dodge Durango 5.7 HEMI, when I shift my car from Park to Drive, it won't shift. The shifter seems like it won't engage and only when it's warmed up, it then shifts. During the Spring and summer, it's fine, no problem. Only when it's cold, I can't shift it. Has anyone had this problem?
Old 01-06-2012, 07:58 AM
Foskey's Avatar
Foskey
Foskey is offline
I have seen in a past thread somewhere that the tranny takes longer to engage during the cold weather. Trying starting the vehicle. Waiting 5-10 seconds, then putting it in gear and let us know what happens.
Old 01-06-2012, 08:26 PM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Dodge Forum Moderator
master tech is the transmission wizard on this site and the far reaches of the galaxy,
FF
Old 01-07-2012, 08:19 AM
captain11's Avatar
captain11
When I start it up this morning, I had to wait at least 4 minutes before I can put it in gear. When I bought the truck new, I never had this problem. Now, I ran the onboard diagnostic where you turn the key in/ engine off position 3 times and it came back with no errors. Any suggestions is much appreciated.
Old 01-08-2012, 04:14 PM
tinmanwpk's Avatar
tinmanwpk
tinmanwpk is offline
Lots of time when you have tranny problems the key dance won't show codes. Take it to a parts store and have them use a code reader.
Old 01-12-2012, 09:48 PM
n8ech's Avatar
n8ech
n8ech is offline
While I am far from a trans expert, I would start by making sure fluid level is correct.
Trans fluid expands as it warms, and if the level is low enough the trans wont work until what is in there expands abit.
How many miles on the D, and has the trans ever been serviced?
Don
Old 01-13-2012, 06:41 AM
captain11's Avatar
captain11
Default Engine won't shift when it's cold
I had my tranny serviced and had the fluids replaced and they told me there was nothing wrong. The only thing I see is that in colder weather, the rpm's go up a bit and once it hits around 800rpm, then it shifts, probably to prevent over revving in gear i'm guessing.
Quick Reply: Car won't shift when it's cold
