2nd Gen Intrepid 1998 through 2004 Intrepids
3.2 Timing Belt Installation
Old 04-09-2011, 07:00 PM
MDThomas26's Avatar
MDThomas26
MDThomas26 is offline
Default 3.2 Timing Belt Installation
I am getting ready to re-install my timing belt.
Can someone tell me this. If I have the crankshaft sproket mark lined up with the TDC mark do I want to have the little line on each cam shaft sproket splitting the two dots that are on each side of the back timing belt cover(s)?
My next question is, if they are NOT lined up -- do I just turn them to get them lined up? Do I need to go a certain direction?
Thanks for any help that is out there.
Old 04-28-2011, 08:30 PM
blukala's Avatar
blukala
blukala is offline
hello thomas , have you got any replies to your questions. Im also going to be doing my first timing belt installation on an intrepid 3.2 1999 this saturday. My third timing belt installation. This is my buddies ride . any info you may have would be helpful. If you did yours already please write back . Ill check back tomorow .
Quick Reply: 3.2 Timing Belt Installation
