03 Intrepid, Flickering problem
I have a 03 Intrepid 2.7 and the lights flicker, all of them. Some days it's better than others, on the really bad days the radio snaps and shuts off, it will click and flicker on and off until the low battery light comes on. I pull over shut the car off, start it, and the light goes off. Lights flicker with car off and key turned, the interior light flickers if the door is open and no key in at all.
I changed the alternator, it has a new battery, all the connections I can find under the hood and under the car have been checked and nothing is loose or corroding. I have had the drivers door panel off and checked connections inside drivers door because someone tried to break into my car, causing window issues. So I checked them. I have pulled the fuses for windows, door locks, and abs sensors (abs and ebrake light on dash will turn on and off while driving) When I lock the car most of the time the door lock beep does not work, but I am assuming this is related to the flickering causing the battery to not get enough of a charge. The car starts every time and it has been going on for about 6 months now, I'm at my wits end. Any help would be great.
Freaking Flickering lights
Hi
Don't have the answer I feel your anxiety. I wanted to join you in hope that someone will reply with help.
I have the same problem. I wondered if there was glitch in my neighborhood in regards to electrical that might of set off the lights in my car. Hope we get a reply.
I have the same car
I have the same car
I no longer have the means to help 100% (I lost my service manuals and schematics to a house fire) but I can point you in a direction...every thing you mentioned points to the BCM (body control module). It is the computer that controls the lights, indicators, alarm, gauges, etc.
Hope this helps you find a direction to pursue.
