PO204 injector open circuit help?
so my cel keeps popping on and every time I check it it says PO204 which is open circuit injector 4. My question is has anybody experienced this? Is there an easy fix? I tried tapping on it to see if it was just stuck but it didn't help. Should I clean the connector? Should I replace the injector? Should I just run some injector cleaner through the tank? Thanks for your help fellas.
Ok so how would I go about relieving the pressure? Just press on the little tire valve looking thing on the end of the fuel rail? Then pull the fuel rail and trade injectors around, reassemble and see if the CEL indicates cyl 3 instead of 4. If it does then that would mean I have a bad injector, and should replace, but if it still says cyl 4 then it is prob a wiring issue or short? Just trying to clarify as this is the first issue I have had with this car in 2 years and I don't wanna mess anything up. Lol.
