aftermarket exhaust
Old 01-21-2017, 01:12 AM
dodgeneon2003's Avatar
dodgeneon2003
dodgeneon2003 is offline
Default aftermarket exhaust
I recently purchased my used 2003 neon, the engine overheats on trips that span longer than an hour, I looked at a few forums and noticed a lot of people seem to be putting exhaust on the car, so where should I get an new exhaust/air and what should the brand be?
Old 01-21-2017, 09:45 AM
jkeaton is offline
Dodge Forum Administrator
Exhaust has nothing to do with overheating. You should focus on that first.
Old 01-21-2017, 09:51 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
So...do you want exhaust recommendations or are you asking how to fix the overheating problem?
Old 01-22-2017, 09:37 AM
jkeaton is offline
I can't tell. Lol.
Old 01-22-2017, 08:39 PM
dodgeneon2003
i was wondering if exhaust would help, what would help the most with overheating
Old 01-23-2017, 07:48 AM
jkeaton is offline
Servicing the cooling system will help the most.
Old 01-24-2017, 12:51 AM
darthroush's Avatar
darthroush
Section Moderator
Start by checking the radiator cap gasket and replace the cap if the gasket is worn, cracked or missing pieces. It's probably the original cap, so $5-$10 for a new one certainly wouldn't hurt regardless. Also, check the coolant overflow system (hose and reservoir) for any blockages.
