The Replacement Truck.
#41
Nice looking truck. I hope you get the bugs figured out. We've got a V10 in our Ford Excursion, we love it. Once winter is over it gets in the double digits MPG. Likes longer trips, 13-14 MPG. It has the Banks power pack on it. No tuner yet though. It made enough difference that you could feel it. I hope your new truck treats you good!
#42
Nice find ....I agree with a good idea to get a replacement crank sensor. I've ordered them through a few places that say they have original mopar part, but a day after you order, they notify you saying they don't have them. I finally had luck on Ebay under 56027864 (I think Standard makes it).
That reminds me I have some door work to do too.
#43
Headlights, new bulbs, heavy duty harness, and TPS are in. Battery is still out, and debating on whether I really wanna do the thermostat tomorrow.... Probably will... I have the alternator, and a/c compressor out of the way, just not looking forward to the mess coolant invariably makes.... I DO want better heat though.
Discovered that the battery clamp wasn't in there, as one of the spots where the spring nut is supposed to clip, is broken off. Which means I may need to replace the battery tray.... (anywhere from 50 to 100 bucks on ebay.....) I am considering trying to use a toggle nut on that one.... I think there is enough room, and, it isn't like I take the battery out regularly. (I don't think I have ever taken the battery out of the 96, after it was replaced....) Other alternative is take the tray out, and manufacture something for the spring nut to hold on to..... not sure which direction this is going to take yet.. I think getting the tray out of the truck is going to be interesting. Couple of the nuts are REALLY rusted in place, and, it's plastic, so, the hot wrench just isn't an option. (If I want to re-use it.....)
#44
#45
#46
Well, got the thermostat done, truck all buttoned up, coolant topped off, etc. I can already see that my unstable idle problem has been solved. Haven't driven it yet to see if the TCC is better. Gonna go catch some dinner soon, will take the truck, and see what happens.
Also discovered that the temp gauge in the truck LIES! Computer said 190. (conveniently enough, the temp of the new stat that I put in.....) Gauge wasn't even close to the 210 mark. About half-way between the "normal range" lower mark, and 210. Different from my 96, but, hey, it's new, it works, I am happy. Heater will now burn you out of the truck.
Need to replace the serpentine belt though. Noticed it was pretty worn, so, will pick one up monday after work, keep the old one as a spare.
I seem to be getting right about 10 miles per gallon... Which is about what I expected, and not really that much worse than the 5.9 in the 96. That averaged around 12 with my driving. I would like to see the 8.0 do better, but, I am not going to hold my breath.
#47
Just got back from town. The TCC bounce is gone. Headlights are aimed, bumper is tightened back up. (had to lower it some to swap out the headlights.) Lighten is DRAMATICALLY improved. Given all the new parts I just threw at it, I am fairly well pleased with the results. Next, I need to address the yellowed fog light lenses, and fix the one that doesn't work at all.
Suggestions?
Suggestions?
#48
3M headlight restoration kit and finish off with clear coat. I've done mine twice and both times with great results, but the first didn't last so the second time I used a can of clear coat and that was in 2013. Just be sure to charge your drill batteries. I always seem to forget!
And your gauge is not lying. It's not an even range between far left and right. 140 210 260 means the first 'half' is 70 degrees and the second is only 50. If it runs between the second mark and 210 you've got 190 degrees. 195 runs just under the 210 and 180 runs a third above the second mark. Hard to explain, but from what you described, it sounds normal!
#49
Good to hear you got heat too. I'm pretty sure I need to get a new core.
Also sounds like that thing is pretty tuned if you're getting 10 mpg.
#50
