Engine Code P0441
Old 09-15-2012, 10:01 AM
caramon's Avatar
caramon
caramon is offline
Default recall
There is a recall for the evap system on some dodge trucks.. I know mine is a 96 and i have 2 recalls one for a electrical problem with the fan blower and the other is for the evap system.
Old 06-12-2013, 04:04 AM
romaine973's Avatar
romaine973
romaine973 is offline
My car has the same code. What should I tell the dealer to fix?
Old 06-12-2013, 07:14 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
pictures and discussion on P0441, P0442, P0455
evap leaks are usually cracked vac lines or loose gas cap.
https://dodgeforum.com/forum/2nd-gen...-leak-fix.html
Old 06-12-2013, 12:47 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
Don't tell the dealer to fix anything. Tell them what the problem is, and then THEY will tell YOU what needs to be fixed.
Old 07-07-2013, 05:01 PM
odzmaker's Avatar
odzmaker
odzmaker is offline
I just got this code myself, and I just bought this truck and still have yet to have the E Test done. Instantly first thought was "Damn it O2 sensor right off the Bat FML !!" lol
After i got the code it occurred to me i had just gotten gas not 20 minutes before the Check engine light came on. I really hope it was just the loose cap , I detest tracing vac lines.
Old 05-26-2016, 11:05 AM
4STFire's Avatar
4STFire
4STFire is offline
Had this issue a while ago and it just came back. Last time replaced the evap solenoid and the evap canister. The canister had deteriorated and was spilling charcoal into the lines. The solenoid was stuck open and likely had a chunk of charcoal stuck in there somewhere. Tried to clean solenoid with compressed air, but that didn't help. Blew out all the lines before installing new components. That fixed lasted 3 years.
Recently I had to install new rear leaf springs and had to move the fuel tank to rear the front driver leaf bolt. I'm wondering whether shifting the tank slightly caused some fuel system line to be loose resulting in the P0441 code. I cleared the code and was good for a few weeks and came back today. Now I'll dig into the search for the source. Any ideas besides checking the solenoid and lines?
Old 05-26-2016, 12:32 PM
HeyYou is offline
Check the vent line on top of the tank. Might have stressed it too much.
Old 05-27-2016, 10:51 AM
4STFire's Avatar
4STFire
4STFire is offline
That makes sense. I'll check there first. Thx
Quick Reply: Engine Code P0441
